1907
Highlighted
Beginner
Unity Connection 8.5.1 not deleting deleted messages
I am running CUC Version 8.5.1ES16.11900-16. My users mailboxes are now filling up because Unity Connection has stopped deleting deleted messages. I have check and changed the Message Aging Policy to permanently deleting messages in the deleted Items folder to 1 day and still having the issue.I have confirmed the issue by leaving then deleting a message to myself and it has been a week and it still is there.
Does anyone have any ideas on what I could check or further troubleshooting I could do.
Bill
7 REPLIES 7
Highlighted
Rising star
Stupid question. Is the appropriate Message Aging Policy selected under User's Mailbox settings?
Highlighted
Rising star
Also have you rebooted your CUC server(s). We've seen the same issue resolved after a reboot.
Highlighted
All users have the default policy and I modified that policy. I even tried to create a new policy and applied it to my mailbox with the same result.
I have not tried rebooting, I can try that. May I ask what version you had the issue on?
Highlighted
I believe it was also on 8.5.
Highlighted
We have just started experiencing this same problem, Unity Connection version 8.5.1ES47.12900-47.  Wondering if the reboot worked and/or what resolved the issue?
Highlighted
Hall of Fame Community Legend
Hi Cheryl,
Just wondering if you had seen this bug? It looks like 95 TAC cases related to this
issue;
CSCtr43597 - UC 8.5 / 8.6.1 Message Aging Does Not Work
Description
Symptom:
UC 8.5 / 8.6.1 message aging policy set to purge deleted messages after one day
and it does not purge messages.
Conditions:
The root cause is known:
If the difference between the MessageModificationtime+DeleteAgingRuleNumDay and
the SystemCurrentTime is more than 99 days,  the exception" Overflow occurred
on a datetime or interval operation"  is thrown by Informix as part of SELECT
query on VIEW vw_MessageAging.
And the MessageAging procedure is aborted.
Workaround:
Contact Cisco TAC for workaround
Details
First Found in:                          (1)
8.5
Status:
Fixed
Last Modified:
May 29,2013
Fixed in:                          (7)
8.6(2.10000.30),8.6(1.98000.53),8.6(1.98000.126)
8.6(1.64),8.5(1.13031.1),8.5(1)ES56,1.0(0.98000.42)
Product:
Cisco Unity Connection
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
Highlighted
Thanks Rob -
I've been searching for anything related to this. We've been on this version for almost 2 years.The problem only started in the last few month's - and it doesn't seem to affect all users, which has made it difficult to isolate. I have tried everything that's been mentioned, yet still have the issue periodically.
I'll contact TAC - Thanks so much.
