08-28-2012 01:41 PM - edited 03-16-2019 12:55 PM
Hello Experts -
We are running Unity Connection 8.5. I know where to change the message playback order for individual users, is there a way to change the default settings for the whole system for message playback order for new messages?
Thank you very much
Sarah P
Solved! Go to Solution.
08-28-2012 02:07 PM
Hi Sarah,
This can also be changed at the "Template" level which will apply to all
users who are created using that Template after the template has been
changed (It's not retroactive )
For existing users you can change them using the Bulk Edit tool.
Cheers!
Rob
"Every fool's got a reason to feelin' sorry for himself" - Springsteen
08-28-2012 02:07 PM
Hi Sarah,
Cheers!
Rob
08-28-2012 02:09 PM
Excellent, thank you so much!
