854
Highlighted
Unity Connection 8.6 Directory Handler Message
I'm trying to find and eventualy replace the directory message that pops up when you pick up the handset, dial your voicemail (envelope key) and then press the # key.
There is a message there that we evidently posted some time ago, but now I need to update/replace it.  I have the new message, I just can;t seem to figure out how and where to put it.
4 REPLIES 4
Highlighted
Participant
Hello David,
If i assume properly you probably want to update the greeting for the Directory handler right?
Go to the directory handler> Edit> Greetings
David        David
Highlighted
To add a tip to what David suggested (+5 P David) click on play/record button and a java application would start.
Than, on the top left of this app you can choose "use computer" and from there you can upload the new prompt.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Highlighted
I attempted these steps (all of them) prior to opening the discussion.  I have a wave file that I'd like to use and even if I apply that file to the Directory Handler, it doesn't appear to actually get updated.  After Saving the update, is there something I need I do to Unity to make it stick?
Highlighted
Hall of Fame Community Legend
Hi David,
First off, +5 to David & Carlo for their great tips here!
I would use this Tool from the great suite of Unity Tools to have a look at the call flow
on a "test" call to see where the call goes when you press # so you can change
the greeting on the proper Handler
Port Status Remote Monitor for Connection (rPSM)
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Here where I do the exact steps you mentioned in your original post. You will see
where I press # here;
Event is [TT#Event]
And then I'm routed to the Opening Greeting Call Handler in this test case;
Playing greeting for Call Handler:  Opening Greeting
06:54:20, New Call, CalledId=8700,  RedirectingId=,  Origin=16,  Reason=1,  CallGuid=946CF65005DF4A2884EDB9538B7EDA15,  CallerName=Rob Huffman,  LastRedirectingId=,  LastRedirectingReason=1024,  PortDisplayName=CallManager-1-001,[Origin=Invalid],[Reason=Invalid]
06:54:21, AttemptSignIn
06:54:21, State - AttemptSignIn.cde!Dummy
06:54:21, Event is [NULL]
06:54:21, SubSignIn
06:54:21, Subscriber Sign-In
06:54:21, State - SubSignIn.cde!AnswerPhone
06:54:21, Event is [TrueEvent]
06:54:21, State - SubSignIn.cde!AuthenticateUser
06:54:21, -->SubAuthenticate
06:54:21,         State - SubAuthenticate.cde!TryCounter
06:54:21,         State - SubAuthenticate.cde!GatherID
06:54:21,         Event is [FalseEvent]
06:54:21,         State - SubAuthenticate.cde!LoadSubscriberMinimalData
06:54:21,         State - SubAuthenticate.cde!GatherPIN
06:54:21,         -->SubAuthenticatePW
06:54:21,                 State - SubAuthenticatePW.cde!ValidatePwd
06:54:25,                 Event is [TT#Event]
06:54:25,         <--SubAuthenticatePW
06:54:25,         State - SubAuthenticate.cde!RouteToNextConversation
06:54:25,         Event is [NULL]
06:54:25, AttemptSignIn
06:54:25, State - AttemptSignIn.cde!Dummy
06:54:26, PHTransfer
06:54:26, State - PHTransfer.cde!LoadInfo
06:54:26, Event is [TrueEvent]
06:54:26, PHGreeting
06:54:26, State - PHGreeting.cde!PlayGreeting
06:54:26, Call answered if needed
06:54:26, Playing greeting for Call Handler:  Opening Greeting
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
