01-22-2013 01:52 PM - last edited on 03-25-2019 08:20 PM by ciscomoderator
I'm planning to upgrade a unity connection 8.6 to 9.1.1.
Currently, I can't see any locale for Germany in version 9.1.1.
Should I install 9.0 and the 9.0 locale and upgrade then to 9.1.1.
Or should I stay with 9.0? Can I upgrade to 9.1.1 and install the 9.0 locale?
Any recommendations or experience with this?
Thanks for you're help/ideas.
Best regards
Steffen
01-22-2013 02:03 PM
Hi Steffen,
Here is the latest info from December 12,2012;
Note
All the locales, other than ENU, for Unity Connection 9.1(1) will be released soon.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/release/notes/911cucrn.html#wp1567630
And
Note
Make sure that the multilingual .cop files are installed on the exact specific CUC build that they were created for. Applying incorrect .cop files for your specific version results in an unexpected behavior of the user conversations.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/upgrade/guide/9xcucrug027.html#wp1053716
So you would have to wait for the 9.1 files to be released
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
01-22-2013 02:33 PM
I'd second that 'wait' recommendation (+5) - CUC locales can be quite late, and having an incorrect one can stop cause conversations to drop out to the failsafe one.
Aaron
01-22-2013 02:59 PM
i concur with my colleagues, I ran into similar delay with previous versions of UCXN and best bet is to open tac case to see when they expect it.
Chris
04-21-2015 09:05 PM
How about if we need to upgrade the CUC version from 9.1.1 to 9.1.2. Should we upgrade the Language Locale from 9.1.1 to 9.1.2 release as well?
04-22-2015 02:29 AM
Hi Kelvin
Yes, you should.
Aaron
04-22-2015 02:46 AM
Thanks for your reply
04-22-2015 08:24 AM
No problem.
Please remember to rate useful responses appropriately...
03-25-2013 10:53 AM
I agree with Rob and Chris, the best course of action is to wait until the locale is released.
Before I go and ask TAC, has anyone got an update on the release date for the UK English locale?
04-04-2013 06:20 AM
For information, if anyone else is looking for the UK English locale for CUC 9.1(1a), the advice I got from TAC is that the Locale for unity Connection 9.1(1a) is the Locale 9.1.0.1-32 (File: uc-locale-en_GB-9.1.0.1-32.cop.sgn). The release notes just said
"All the locales, other than JPN, are released for Unity Connection 9.1(1)."
They didn't specify what releases of the locale are compatible and there don't appear to be any release notes for the locale pack itself.
04-04-2013 06:26 AM
Hi Vincent,
Thanks for this kind follow-up! +5 for letting the
community know about the updates
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
