1399
s.lehmann
Beginner
Unity Connection 9.1.1 locale
I'm planning to upgrade a unity connection 8.6 to 9.1.1.
Currently, I can't see any locale for Germany in version 9.1.1.
Should I install 9.0 and the 9.0 locale and upgrade then to 9.1.1.
Or should I stay with 9.0? Can I upgrade to 9.1.1 and install the 9.0 locale?
Any recommendations or experience with this?
Thanks for you're help/ideas.
Best regards
Steffen
10 REPLIES 10
Rob Huffman
Hall of Fame Community Legend
Hi Steffen,
Here is the latest info from December 12,2012;
Note
All the locales, other than ENU, for Unity Connection 9.1(1) will be released soon.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/release/notes/911cucrn.html#wp1567630
And
Note
Make  sure that the multilingual .cop files are installed on the exact  specific CUC build that they were created for. Applying incorrect .cop  files for your specific version results in an unexpected behavior of the  user conversations.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/upgrade/guide/9xcucrug027.html#wp1053716
So you would have to wait for the 9.1 files to be released
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
I'd second that 'wait' recommendation (+5) - CUC locales can be quite late, and having an incorrect one can stop cause conversations to drop out to the failsafe one.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
i concur with my colleagues, I ran into similar delay with previous versions of UCXN and best bet is to open tac case to see when they expect it.
Chris
How about if we need to upgrade the CUC version from 9.1.1 to 9.1.2. Should we upgrade the Language Locale from 9.1.1 to 9.1.2 release as well?
Hi Kelvin
Yes, you should.
Aaron
Thanks for your reply
No problem.
Please remember to rate useful responses appropriately...
vincent.morton
Beginner
I agree with Rob and Chris, the best course of action is to wait until the locale is released.
Before I go and ask TAC, has anyone got an update on the release date for the UK English locale?
vincent.morton
Beginner
For information, if anyone else is looking for the UK English locale for CUC 9.1(1a), the advice I got from TAC is that the Locale for unity Connection 9.1(1a) is the Locale 9.1.0.1-32 (File: uc-locale-en_GB-9.1.0.1-32.cop.sgn). The release notes just said
"All the locales, other than JPN, are released for Unity Connection 9.1(1)."
They didn't specify what releases of the locale are compatible and there don't appear to be any release notes for the locale pack itself.
Rob Huffman
Hi Vincent,
Thanks for this kind follow-up! +5 for letting the
community know about the updates
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
Create
Recognize Your Peers
Content for Community-Ad
