Unity Connection -- CME integration
nafrasiyabov
Hi people.
I have some issues when integration UC-CME via SCCP. Every thing works just fine except MWI lights do not work on SIP phones.
Here is the config from CME router:
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
sip
  bind control source-interface FastEthernet0/0.200
  bind media source-interface FastEthernet0/0.200
  registrar server expires max 600 min 60
voice register global
mode cme
source-address x.x.x.x( FastEthernet0/0.200) port 5060
max-dn 20
authenticate register
voicemail 4001
tftp-path flash:
voice register dn  1
number 3002
call-forward b2bua busy 4001
call-forward b2bua noan 4001 timeout 7
allow watch
name BR2 Phone 2
mwi
voice register pool  1
id mac XXXX.XXXX.XXXX
type 7970
number 1 dn 1
presence call-list
dtmf-relay sip-notify
username farmer password cisco
codec g711ulaw
sip-ua
mwi-server ipv4:y.y.y.y expires 3600 port 5060 transport tcp unsolicited
telephony-service
max-ephones 20
max-dn 20 no-reg
ip source-address x.x.x.x port 2000
voicemail 4001
max-conferences 8 gain -6
call-forward pattern .T
mwi relay
ephone-dn  1  octo-line
number 3001 no-reg primary
name BR2 phone 1
allow watch
call-forward busy 4001
call-forward noan 4001 timeout 9
ephone-dn  10  dual-line
number 4001
preference 1
huntstop channel
no huntstop
ephone-dn  11  dual-line
number 4001
preference 2
huntstop channel
ephone-dn  20 dual-line
number 8000 secondary 8001
mwi on-off
ephone  1
device-security-mode none
mac-address XXXX.XXXX.XXXX
max-calls-per-button 5
busy-trigger-per-button 3
username frank password 12345
presence call-list
type 7965
button  1:1
ephone  10
vm-device-id CUC-VI1
button  1:10
ephone  11
vm-device-id CUC-VI2
button  1:11
john.nield
from you problem description it sounds like you VPIM integration is ok?
in you config i cannot see the incoming and outgoing SIP dial-peers between the CME and CUE,
i would suggest you run the debug CCSIP messages and check the MWI notify message is being sent to the CME, and what CME is sending back to CUE.
can you confirm the dial-peer config and send through the debug out.
thanks
John
Hey there. thank you for your reply.
The thing is that I integrated CME with Unity Connection ( not Unity Express) . And integration made over SCCP, so there is no need for SIP dial-peers according Cisco Doc.
Any advice ?
Have you tried the port status monitor to confirm that CUC is sending the MWI??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
