Unity Connection - Disaster Recovery - WebUI hangs on Manual Backup
Chadster766
System: Unity Connection version 10.5.2.11900-3
When I'm in the Disaster Recovery WebUI and click Backup => Manual Backup the browser hangs.
All services that are activated features services and network services are running except "Cisco DRF Local[STOPPED]  Component is not running" keeps happening.
Nothing help just:
[ServiceName=Cisco DRF Local][Reason=Service stopped abruptly][ClusterID=][NodeID=ucn1]: Service terminated.
What would happen if I restarted the DRF Master service and then started the DRF Local service?
Edit: Restarting the DRF Master service resolved the issue of the DRF Local service failure to start allowing backups to be run.
5 Replies 5
Chris Deren
Can you restart DRF services? Have you tried rebooting as I have seen these services hung and reboot fixes it? Have you looked through the DRF logs?
I haven't restarted the CUC because it's a major system but I suppose I could restart it after hours. Do you think this is the only solution?
I don't know if that will even fix your issue for sure, something that I have run into in the past.
What happens when you restart the service?
What do you see in the logs?
Nothing help just:
It's worth trying as it would have no adverse affect on anything else.
