295
Highlighted
Beginner
Unity connection dont answer the call
Hi voice team, id had a problem with my unity connection 8.6.
When i press the mailbox button in my deskphone, the unity connection dont answer.
I recently change the server, because the other server crashed.
Thiago
6 REPLIES 6
Highlighted
Hall of Fame Cisco Employee
Start by checking the CUCM-CUC integration, if SCCP, make sure ports are registed and properly configured on both sides.
Check all the VM config in CUCM, and if all looks good, use the port status monitor to see if you're reching CUC or not.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Highlighted
Hi Jaime, i check the port status and its OK.
Attached are the status.
Highlighted
Use the port status monitor tool to check if the calls are getting to the serrver. You can copy and paste the output here
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Highlighted
How the port status monitor tool work ? I installed im my windows, but when i click System -> Add local system, a error appears: "Unable to open key..."
Highlighted
There is a training video available for this tool.Please go through it
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Highlighted
in the video he teaches using another program, I could not run here.
