Unity Connection > Users > Import Users takes forever
Jason Aarons
Level 6
Level 6
My Import Users is problematic : (
We are LDAP integrated, with LDAP authentication and Dir Sync is running.
I click on Users > Import Users and then wait 3-4 minutes the screen will show up.
Unity Connection 10.5.1.10000-7 with IE 9 running Windows 7 and Java 7 Update 51.
Server CPU is mostly idle etc.
yahsiel2004
Level 7
Level 7
Does it perform any better when ran on a different browser?
HTH Regards, Yosh
Brandon Pierce
Level 4
Level 4
Couple of things I have questions on:
  1. Is this the only thing that runs slow on Unity?
  2. Is this a VM?
  3. How much RAM is allocated?
  4. What does the VM report if it is a VM (resource utilization wise since the cpu is not being taxed)?
  5. When you do a utils network ping between Unity and CUCM what are the response times?
Sounds like something network related but it could be with the servers themselves.  Also, yahsiel's recommendation is a good idea to check as well.  Try firefox or chrome and see if there is a difference.
