Highlighted
Explorer
Unity Connection Install Stalls at NTP
rebuilding  Unity 8.6 Publisher onto a VM and the install stalls at the NTP server discovery.  I am having network connectivity issues right now.  Any way to skip past the NTP just to get the software installed and deal with the network connectivity issues after the app is up?
replies rated
2 REPLIES 2
Beginner
I believe this isn't possible
I believe this isn't possible to skip NTP reachability to complete installation. If you have trouble reaching out NTP on WAN, try to simulate a NTP on a router in your LAN and make sure unity can reach it. Once the application is up, you can modify NTP server entries.
You need at least one NTP server to complete installation of CUC
Refer: Installation guide of CUC 8.x
Sami
Participant
Hi Scott,
Hi Scott,
May be you can try making the ESXi itself as a NTP server.
Try this.
Please rate if helpful.
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
Content for Community-Ad
July's Community Spotlight Awards
