Unity Connection Message Time
Mojo1
Beginner
Beginner
We have UC 2.1.1 and the time when a message is left is off by one hour, how do you correct this is the server time is correct?
Clifford McGlamry
Rising star
Rising star
There are several things you need to verify here.
1. Is NTP set correctly on UC and syncronized?
2. Do you have the correct time zone set on the server?
3. Do you have the correct time zone set on the user (if they aren't in the same timezone as the server)?
I know there are a few one off timezone settings that don't follow DST, and as a result, a user erroneously pointed at one of these might have time off by an hour about half the year.
Recognize Your Peers
