02-16-2011 07:29 AM - edited 03-16-2019 03:29 AM
I'm trying to install Unity Connection 8.0.2 on UCS B200 through OVA template.
It creates the VM fine, but when it come to install Unity Connection, there is no option for Unity Connection!
Only Call Manager and BM Business Edition is listed!
If I put in the image for 8.0.3, I see the option for Unity Connection!
Is there something wrong with my iso file?
Or do I need to edit VM setting? like more memory and extra CPU?
Is it maybe possible that I'm not seeing that Unity Connection installation option because the HW assigned to that VM through OVA
is too small to run Unity Connection VM? (I'm saying this because it only assigned 2GB of memory, 1CPU, and 160GB HDD for Unity)
too small memory? or cpu?
I think, I'll try installing with 8.0.2 DVD!
I'll let you guys know how it went.
P.S. I am trying to upgrade 8.0.2 on MCS to 8.5.1 on UCS.
So I'm trying to install 8.0.2 on VM through OVA restore the files, and upgrade to 8.5.1
That's the proper process...right?
06-25-2011 02:42 PM
Thomas, did you figure out this issue? I am facing the same issue trying to int CUC 8.5 with the 500 user template.
thanks
06-25-2011 03:17 PM
As per this link, the configuration should be enough (1 vcpu, 2gb ram) for the version you are trying to use (8.5)
06-25-2011 03:26 PM
I was using the 500 user OVA with 1 cpu, 2 GB ram and 160 GB of disk but it will not work. I changed the ram to 4 and CPU to 2 and it now gives me the CUC option.
06-25-2011 03:37 PM
i d suggest get the OVA file for the 1000 user and see if the behaviour changes...thats interesting to know...
06-25-2011 03:23 PM
Unity Connection also requires one physical core to remain idle for ESXi Scheduler:
HTH,
Chris
