Walkthrough Wednesdays
663
umeshplamthottam
Beginner
Unity connection standard greeting not playing
In our Setup - We have a main line number and if someone call to that number it will ring for some time and then it is forwarded to Voice mail(CFW_NO_AN) then it will play a recorded message and allows caller to drop a voice message after the greeting, Previously it's playing our recorded greeting in standard greeting but now it's playing "cisco unity connection messaging system ............." greeting
How to fix the issue.
this setup is deployed with CUCM 11.5 and CUC 11.5
In Standard greeting
Greeting enabled with no end date.
Callers hear
My personal recording is selected
After greeting
Call action is take message.
We can hear that recording in this recording console.
1 ACCEPTED SOLUTION
If call land on Reception phone then it forward to  hunt group which gets forwarded to Reception mail box in CUC, you need to  disabled  Use Last (Rather than First) Redirecting Number for Routing Incoming Call. IF disabled CUC will use Reception  DN  as first redirecting number and you will get he reception mailbox greeting. if enabled CUC will use HUNT pilot number and there won't be any mailbox configured and you will hear default greeting.
if call land on CTI>Reception>Hunt Group>Voicemail, enabling   Use Last (Rather than First) Redirecting Number for Routing Incoming Call option will use CTI number as the redirecting number. and if you disable   Use Last (Rather than First) Redirecting Number for Routing Incoming Call CUC  will use HUNT pilot number as the redirecting. call doest goes to Reception mailbox.
in that Cse you may need to try the below.
case 1 Use Last (Rather than First) Redirecting Number for Routing Incoming Call "DISABLED"
  • Create a Call Hander with CTI  number. Record a greeting, and set the after greeting action to "Take Message".
  • Create a distribution list and assign the Reception mailbox.
  • Assign the distribution list to the Call Handler message settings.
case 2 Use Last (Rather than First) Redirecting Number for Routing Incoming Call "ENABLED"
  • Create a Call Hander with HUNT PILOT   number. Record a greeting, and set the after greeting action to "Take Message".
=>>>If this answered your question, please click "ACCEPT AS SOLUTION"<<<=
=>>>If you find this response useful, please mark it as "HELPFUL"<<<=
9 REPLIES 9
Mohammed al Baqari
VIP Advisor
Make sure that the voicemail user created in CUC has the same number as the
forward DN. Seems that CUC isn't able to find a match for forwarding DN.
**** please remember to rate useful posts
Nithin Eluvathingal
VIP Advocate
"cisco unity connection messaging system ............." this is default greeting message which unity play when it fail to find a match.
you have mentioned that it was working previously, so what changes was made on configuration side?
I don't know what changes are made
The exact setup is CTI route point - >reception phone then the call is forwarded to hunt pilot (call hunting setup) if no one in line group picked the phone then only it will reach cuc.
Just confirm that DNs in CUC matches the reception number
Yes, verified both are same.
CTI route point - >
so u mean the call land on CTI route point first then forward to Reception, and then to Hunt pilot and if not answered it goes to CUC ?
Yes, but now calls are not forwarded to hunt pilot, directly to voice mail box.
Hi Nithin & Mohammed ,
Thanks for your support, now my shift time is over I will try these modifications on tomorrow and I will update Here.
Content for Community-Ad
Spotlight Awards 2021
