Unity connection
eric.bias
Beginner
Beginner
we have installed cucm 6.1.3 n unity connection 6.x. we have notice that when upate Primary extension of end user, this en user is available for import on unity connection. After we are importe this en user in unity "import users" it's not possible in call manager to view this end user. when we delete this user in unity he re appear again in cucm.
does anyone tell us if this normal?
CUCM 6.1.3
Ucx:6.x
Many thanks
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
there is no CUC 6.x
if this a BE mention it
if you update the primary extension you do not reimport the user, you simply sync again
java
if this helps, please rate
java
I am hitting this bug after an upgrade to 6.1.3.2000.1 of UCM, and 7.0.2.10000-38.
I am not understanding the workaround.
I tried accessing the ccmadmin by IP address rather than hostname. That didn't help.
I then went to the application server and only have a field for name and IP address. Am I supposed to change the name field to the IP address??
"Workaround:
Change the hostname to the IP address in the URL
If you are getting a blank page, please go to System -> Application -> and hit
find. Choose the UC and change the hostname from to
.localdomain. This should fix the issue. This may or may not be
traffic affecting."
Thanks.
This is bug ID CSCsw97577 and has been fixed as of 6.1.3.1104-2. You can open a TAC case to get special access to the ES if you need to correct it.
Many thanks for your help
Best Regards
