Unity does not pickup when CM Publisher is down
Scott Hanson
Level 3
Level 3
running Unity Connection 8.6 with CM 8.6.  VM ports show registered to Publisher but Unity will not answer calls (or possibly takes too long) when the CM Publisher is off-line.  Any ideas on what might be wrong?
Replies rated.
5 Replies 5
Rob Huffman
Hi Scott,
Can you check these settings in CUC for the "Secondary" server config. This would add the Sub
to the list of available CUCM servers
Step 32 On the Edit Servers page, do the following substeps if the Cisco Unified CM cluster has secondary servers. Otherwise, skip to Step 33.
a. Under Cisco Unified Communications Manager Servers, click Add.
b. Enter the following settings for the secondary Cisco Unified CM server and click Save.
Table 6-16     Settings for the Cisco Unified Communications Manager Servers
Field
Setting
Order
Enter the order of priority for the Cisco Unified CM server. The   lowest  number is the primary Cisco Unified CM server, the higher   numbers are  the secondary servers.
IP Address or Host Name
Enter the IP address (or host name) of the secondary Cisco Unified CM server.
Port
Enter the TCP port of the Cisco Unified CM server that you are    integrating with Cisco Unity Connection. We recommend that you use the    default setting.
TLS Port
Enter the TLS port of the Cisco Unified CM server that you are    integrating with Cisco Unity Connection. We recommend that you use the    default setting.
Server Type
Click Cisco Unified Communications Manager.
http://www1.cisco.com/en/US/docs/voice_ip_comm/connection/7x/integration/cucm_sccp/guide/cucintcucmskinny050.html
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
Thanks Rob,
both Pub and Sub are already listed.
Thanks Rob,
I thought I had waited for longer than that but can check this weekend to make sure.
Rob Huffman
Hi Scott,
Well that's a great start You know.....this takes 2 to 3 minutes
to "fail over" in our environment, it's probably the same for you. Have
you waited that long in your testing? I've never found a way to speed up the process.
Cheers!
Rob
Rob Huffman
Hi Scott,
You are most welcome my friend
Please get back to us after your testing and let us know how
it went. You may want to tweak the settings during your "maintenance"
window to make the Sub the first choice followed by the Pub (best practice)
Cheers!
Rob
