Unity Express compability BE6000
Does Cisco Unity Express version 8.6 on (C2911 Internal Service Module) is compatible with BE6000 version 9.1?
[ ]'s
Jaime Valencia
Yes, however since CUE is not part of the 6K solution, your CUCM wont be any longer considered a 6K if you do so.
java
if this helps, please rate
Hi Rosa,
In addition to what Mr. Jaime has said, BE 6000 is a packaged solution which supports CUCM, UCXN and Provisioning MAnager which is installed on UCS C200 M2 Rack Mount Servers.
Above that, u can also additional components like UCCX,Attendant Console and Presence.But can install max. of 5 applications.
regds,
aman
Thank's Jaime/Amanso,
I just need to use a application (Automated Attendant) included in Unity Express. I wouldn't to waste one VM with this.
[ ]'s
