03-07-2009 07:48 AM - edited 03-15-2019 04:41 PM
Its fresh 2821 router with NME-CUE module
showing this
MPORTANT::
IMPORTANT:: Administrator Account Creation
IMPORTANT::
IMPORTANT:: Create an administrator account. With this account,
IMPORTANT:: you can log in to the Cisco Unity Express GUI and
MONITOR SHUTDOWN...
IMPORTANT:: run the initialization wizard.
IMPORTANT::
Enter administrator user ID:
(user ID): admin
Failed creating admin
Reason: Error in DB operation : SQL Query error; nested exception is:
org.postgresql.util.PSQLException: The backend has broken the c
INIT: Sending processes the TERM signal (y/n)?
Restarting system.
show run is attached herewith
03-07-2009 01:44 PM
It's an Hardware failure. I had the same problem with a new 2811 with a NME-CUE too. And when I made an RMA, I received an other NME-CUE with exactly the same problem !!!
The second RMA received was OK.
Maybe a recurrent problem with NME-CUE.
rgds
jp
03-07-2009 10:43 PM
I have two routers, both of them having the same problem.....
ANY OTHER TROUBLESHOOTING SUGGESTION...
RELOAD UNITY OR WHAT????
03-10-2009 08:01 AM
You can upgrade Unity Express through the Boot Loader, but I don't think it will solve the problem.
I also didn't believe I could have the same problem twice with 2 new modules. Open a TAC SR to confirm.
03-22-2009 03:40 AM
two days ago i had the same problem of reboot with NME-CUE in a 2821.
I resolved this issue with boot helper:
from version 3.2 i had upgraded it to version 7.0.2.
In this way i had successfully install my NME-CUE.
04-08-2009 08:48 AM
Hi all,
You don't need to upgrade or downgrade the software, just re-install the same software version.
for example: CUE Version 2.3.4, dowload the CUE 2.3.4 software
I had the same problem with NME-CUE and I resolved this issue.
Use this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a0080222cbf.shtml#prep1
05-20-2009 07:49 AM
Hi all,
I had the same problem with NME-CUE on 2851. I could recover by re-installing the software via boot helper, however, once the initial wizard completes, it gives the same error message again and keeps on rebooting non-stop.
Did anyone manage to get any answer from TAC? It seems to be a common problem with NME-CUE.
