Community Helping Community
410
Beginner
Unity Express Time issue
Is there any way to change unity express
Data and time manually .
its not syncing with ntp servers.
pls reply
thanks
6 REPLIES 6
Highlighted
Beginner
Re: Unity Express Time issue
Date and time are determined by the Network Time Protocol (NTP) server and cannot be set
in the Cisco Unity Express software. Cisco Unity Express can be configured as an NTP
client. See the NTP configuration section in the Cisco Unity Express 2.3 CLI Administrator
Guide and your NTP server documentation for more information. This is the documentation
for setting this up on the server. These are some commands you can run to check the
connection etc...Is there another NTP server you can try pointing to from CUE (if you
cannot get to the current one?).
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_administratio
n_guide_chapter09186a0080677977.html
Beginner
Thanks very much
i tried configuring more than 2 NTP servers.
but the issue is that its not syncing to any of NTP servers.
thats why i tried to configure manuallly
is there any way to make it sync
pls reply
Beginner
I am having the same issue. CUE does not sync with the NTP servers, and I cannot change the time manually. I even tried setting the NTP server as the router, but that didn't work either. CME time is right, CUE time is roughly 11.5 hours off.
Beginner
I have this working on all my CME/CUE routers. On the CUE config I have the following:
ntp server 10.205.30.1
And this IP corresponds to the one used on the following command under the Service-Engine interface:
service-module ip default-gateway 10.205.30.1
By the way, what is CUE reporting when you run "sh ntp stat" at the command line?
Ron
I tried getting this to work with windows 2003 server etc... no luck
What i did is i configured the router where the unity box is installed on as NTP master.
In conf mode configure the router as NTP master with a stratum of 1
Then in the NM-CUE put ntp server x.x.x.x (ip of your router)
This should now sync your time with the router, be sure you set the timezone correctly on both devices (also manually set the time on the router ofcourse.)
Some helpfull commands
show ntp status
show ntp assoc
hope this helps!
Beginner
My issue is that when we set timezone for Central Daylight time, in CUE 2.1 CDT is not valid. You can only pick CST, but when dailight savings time hits, it still thinks it is standard because CDT is not valid...
Content for Community-Ad
FusionCharts will render here
