01-27-2014 04:44 AM - edited 03-16-2019 09:27 PM
If customer having Unity express running in ISR-300-K9 with version 8.5.1 and wanted to upgrade to 8.6.4 onwards in-order to comaptible with CUCM ver 9.1
Is there any license required for this Unity Express Upgradation from 8.5.1 to 8.6.4 ?
Upgrade document says "Download and install the new CSL license file(s)"
Pls. anyone clarify, this CSL is required only for 7.x to 8.6 NOT for upgrade from 8.5.1 to 8.6.4
Pls. suggest.
Rgds
Rajesh Kumar
Solved! Go to Solution.
01-27-2014 08:56 AM
Hi Rajesh,
You are most correct my friend THe CUE 8.5 build
would already be using CSL licenses so you should be
good to go here.
Cheers!
Rob
"Seek it out and ye shall find "
- OneRepublic
01-27-2014 08:56 AM
Hi Rajesh,
good to go here.
Cheers!
Rob
- OneRepublic
11-03-2014 07:22 AM
Hi, can i just confirm you didn't need to obtain any additional licences
11-03-2014 07:42 AM
Hi Mark,
If current CUE is a version newer than 7.1 you would not need any licensing changes. If current CUE was pre-7.1 you would need to go through the CSL license upgrade.
Cheers!
Rob
11-04-2014 03:06 AM
Hi Rob,
thanks for the reply , i understand the csl issue with pre 7.1 , what i was really aiming is do i need to contact cisco to get a licence for 8.6 or does an 8.5 licence cover all version 8.x
i'm guessing the latter but wanted to confirm that.
cheers
mark
11-10-2014 06:55 AM
Just in case someone needs the info, i spoke with cisco licencing and apparently you can use the same licence.Will be doing on thursday so will let you know how i get on.
Oh and 8.6.9 Unity express is compatible with 10.5 and 8.6.2 CUCM.Its not mentioned in any documentation but i have had it confirmed by the BU.
cheers
Mark
11-10-2014 07:20 AM
Hi Mark,
Thanks for posting back with the results of your research here! (+5) Good luck with this weeks upgrade.
Cheers!
Rob
11-01-2016 11:35 PM
ftp://192.168.2.74/CUE/CUE8.6.10/cue-vm-k9.SPA.sme.8.6.10.pkg
WARNING:: This command will download the necessary software to
WARNING:: complete an upgrade. It is recommended that a backup
WARNING:: before installing software.
Would you like to continue?[confirm]y
Downloading ftp cue-vm-k9.SPA.sme.8.6.10.pkg
Bytes downloaded : 712654
Validating package signature ... done
Validating installed manifests ............complete.
- Parsing package manifest files... complete.
- Checking Package dependencies... complete.
Downloading ftp cue-vm-langpack.sme.8.6.10.pkg
Bytes downloaded : 3983599
- Checking Manifest dependencies for subsystems in the install candidate list...
- Checking Manifest dependencies for subsystems already installed...
complete
Starting payload download
File : cue-vm-full-k9.SPA.sme.8.6.10.prt1 Bytes : 150034428
Validating payloads match registered checksums...
- cue-vm-full-k9.SPA.sme.8.6.10.prt1 ................................................................................................................................................verified
Extracting install scripts ...
/bin/
/bin/
Scripts extraction complete.
Remove scripts work order /
Running Script Processor for ui_upgrade
Upgrading Installed languages (2):
Installed SKU Name (new version)
* ENU CUE Voicemail US English (8.6.10)
* ARA CUE Voicemail Arabic (8.6.10)
ui_upgrade scripts executed successfully.
how to slob this problem
/bin/sutar: usr/etc/tomcat_post_upgrade.py: Not found in archive
/bin/sutar: Error exit delayed from previous errors
totally not upgrade
