Unity Express Wan problem
Hi all,
My problem is the CME or the unity express is dropping the call coming from the wan.
For calls from the PSTN or from the local network the unity is answering correctly.
Anybody know what could be the problem?
I will appreciate any help.
8 Replies 8
paolo bevilacqua
Are you using G711 for wan calls to CUE ?
Otherwise, you need to configure transcoding on the hosting CME.
thanks,
but how this configuration should be done?
this is the dial-peer to unity
dial-peer voice 635555 voip
description To VoiceMail
destination-pattern 63555.
session protocol sipv2
session target ipv4:10.124.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
thanks
To begin with, can you ping 10.124.10.1 ?
Then, take "debug ccsip message" with "term mon".
yes, the ping responding.
The debug I will post later because this can be only done in the non-business hours.
Debug ccsip message can be done at any time, it is of no impact.
The requested debug is attached.
Any ideias?
Did you have a solution to this problem.  I am having a similar issue.
Start a new thread, post up your configuration.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
