09-19-2013 10:33 AM - edited 03-16-2019 07:27 PM
Dear all,
i have one scenerio,for which i need your inputs how to achieve it?
one of our customer is having CUCM 6.1 which is used by group of companies in same building & currently unity 5.0 which is intergrated with cucm 6.1 and is used by one of the group of companies. Now customer wants to add one more untiy connection server for voicemail for one of the compnay on same cucm 6.1. Please let me know can we intergate the same with this scenerio.
09-19-2013 11:07 AM
Hi there,
This is most possible
You will be creating a new integration using new ports, VM profiles etc.
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
09-19-2013 11:53 AM
Thanks Rob for your valuable inputs.
i hope you understand my requirement. untiy 5.0 is alreday intergated with CUCM 6.1 using SCCP protocol. now i need to add another unity connection 9 version in the same CUCM 6.1. is that possible
09-19-2013 12:02 PM
Hi there,
You are most welcome my friend
Yes, I understood your requirements fully and you should be
fine to create multiple integrations between your CUCM and multiple
voicemail systems. In your case it's Unity and Unity Connection
for us it was Octel and Unity Connection. We had both integrations running
for quite some time and thet both worked perfectly.
You can control which system the phone uses by simply changing
their voicemail profile, as the profile will relate back to the specific
integration and control the message button forwarding location (voicemail checkbox) etc.
Cheers!
Rob
- Bob Marley
09-20-2013 02:36 PM
I think I see unity connection 9.
It should be ok as per this link
Haitham
