Unity: Transfer Out of Mailbox
wrickk_2
Is there a way to setup Unity so a user that dials-in to LISTEN to their voicemail can # back out to an operator or menu when they are finsihed?
I see the options to redefine keys for someone that dials in to LEAVE a message for a mailbox... but no options for the user that actually dials-in to his/her mailbox.
rcrumm_2
Level 2
Level 2
Try using the * key once you have listened to your messages.
Randall
Unfortunately that just puts you back at the menu prompting you for user ID and password and there doesn't seem to be anywhere else to go from there.
