AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
292
Beginner
unknown numbers in incoming calls
Dear All
i have an incoming Id problem , it shows me ig the phones " Unknown " number and  not number and this happend not always , it happends sometimes , i have E1 with cucm 7.1 , please see the debug below :
and give me
Jan 26 07:25:20: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x450D
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '263078ْXXX'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '99521XXX'
Jan 26 07:25:21: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xC50D
Jan 26 07:25:21: //219075/80B5AD01662A/CCAPI/cc_api_call_proceeding:
   Interface=0x46032280, Progress Indication=NULL(0)
Jan 26 07:25:22: //219074/80B5AD01662A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x458561F8, Call Id=219074
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Jan 26 07:25:22: //219074/80B5AD01662A/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jan 26 07:25:22: //219075/80B5AD01662A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Jan 26 07:25:22: //219075/80B5AD01662A/CCAPI/cc_api_get_transfer_info:
Jan 26 07:25:22: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x450D
        Cause i = 0x8090 - Normal call clearing
Jan 26 07:25:22: //219074/80B5AD01662A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jan 26 07:25:22: //219074/80B5AD01662A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x458561F8, Tag=0x0, Call Id=219074,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 26 07:25:22: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xC50D
Jan 26 07:25:22: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x450D
Jan 26 07:25:22: //219075/80B5AD01662A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46032280, Tag=0x0, Call Id=219075,
Jan 26 07:25:26: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0060
        Cause i = 0x809F - Normal, unspecified
Jan 26 07:25:26: %ISDN-6-DISCONNECT: Interface Serial1/0:0  disconnected from 94455XXX , call lasted 25 seconds
Jan 26 07:25:26: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8060
Jan 26 07:25:26: //219072/CCC06A40A59B/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x46032280, Call Id=219072
   Call Entry(Responsed=TRUE, Cause Value=31, Retry Count=0)
Jan 26 07:25:26: //219072/CCC06A40A59B/CCAPI/ccConferenceDestroy:
   Conference Id=0x16A64, Tag=0x0
Jan 26 07:25:26: //219072/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x16A64, Source Interface=0x46032280, Source Call Id=219072,
   Destination Call Id=219073, Disposition=0x0, Tag=0x0
Jan 26 07:25:26: //219073/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x16A64, Source Interface=0x458561F8, Source Call Id=219073,
   Destination Call Id=219072, Disposition=0x0, Tag=0x0
Jan 26 07:25:26: //219072/CCC06A40A59B/CCAPI/cc_generic_bridge_done:
Jan 26 07:25:26: //219072/CCC06A40A59B/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=31)
   Cause Value=31, Call Entry(Responsed=TRUE, Cause Value=31)
Jan 26 07:25:26: //219072/CCC06A40A59B/CCAPI/cc_api_get_transfer_info:
Jan 26 07:25:26: //219073/CCC06A40A59B/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jan 26 07:25:26: //219073/CCC06A40A59B/CCAPI/cc_api_get_transfer_info:
Jan 26 07:25:26: //219073/CCC06A40A59B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x458561F8, Tag=0x0, Call Id=219073,
   Call Entry(Disconnect Cause=31, Voice Class Cause Code=0, Retry Count=0)
Jan 26 07:25:26: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0060
Jan 26 07:25:26: //219072/CCC06A40A59B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46032280, Tag=0x0, Call Id=219072,
Jan 26 07:25:32: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0061
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Calling Party Number i = 0x2181, '94455XXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '26307XXX'
        High Layer Compat i = 0x9181
Jan 26 07:25:32: //-1/E002586AA59C/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=94455XXX
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
9 REPLIES 9
Re: unknown numbers in incoming calls
Hello
What is call-flow and topology ?  also past thw config from GW.
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Beginner
Dear Nadeem
thanks for your reply
see the configuration below :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
  h245 tunnel disable
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
controller E1 1/0
pri-group timeslots 1-31
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 1/0:15
dial-peer voice 202 voip
preference 10
destination-pattern 26307...
voice-class codec 1
session target ipv4:X.X.X.10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 301 voip
voice-class codec 1
session protocol sipv2
incoming called-number .
dtmf-relay rtp-nte
dial-peer voice 201 voip
preference 9
voice-class codec 1
session target ipv4:X.X.X.11
no vad
Hello
Can you add this config on your interface Serial1/0:15,
  isdn outgoing display-ie
  isdn outgoing ie redirecting-number
also please share the call-flow topology, Is this call coming from PSTN through this PRI have issue ?
is this your topology?
PSTN--------------<-PRI>---------------GW(h.323)-------CUCM---Phone
Br,
Nadeem
Beginner
Dear Nadeem
yes , it is , your topology is right , as what i have
isdn commands that u sent for outgoing not for incoming , the problem for incoming not for outgoing
i am waiting ur advise ASAP
thanks
Rising star
As per the debug posted above, the provider is seding the calling number to your GW.
        Sending Complete
                Standard = CCITT
>> Please collect ccm traces along with debug h225 asn1 & debug h245 asn1 for a test call.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Highlighted
Beginner
Dear Sureshsubs
i put XXX in calling and called number for security for the customer   , but it is a correct number reached and  the desk phones ringing and i can hear each other but the problem is :
showing me unknown number in incoming calls to my desk phone
Rising star
when you run the debug isdn q931, what do you see as calling number?
Calling Party Number i = 0x2181, '94455XXX' or
Calling Party Number i = unknown?
Beginner
calling party number ! = number (not unknown number)
and this is additional debug
                Standard = CCITT
        Channel ID i = 0xA9839C
                Exclusive, Channel 28
        Calling Party Number i = 0x0081, '26307052'
        Called Party Number i = 0x80, '50198866'
Jan 26 07:25:49: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xC510
what i am thinking , is it from MOC or ISP ? or from my side ?
Rising star
in that case, you still receive the caller ID from ISP as shown in debug isdn q931. we need to check the CCM traces to know why the caller ID is not displaying on the phone. Please collect the CCM SDI logs for a test call and with the debugs I mentioned earlier.
//Suresh
Content for Community-Ad
August's Community Spotlight Awards
