Update PIN enduser - No UPDATE permission for credential
mischm
how can I set / update a new PIN via SQL for a enduser which is used for extension mobility?
I tried this command:
update credential set credentials='new pin' where fkenduser='pkid from enduser' and tkcredential='4'
and get this reply: No UPDATE permission for credential.
Our CUCM is LDAP integrated but enduser pin is editable via CUCM webpage.
How can I update this enduser pin via SQL?
BR
Michae
dojoy
I do not think thats possible unless you have root access to the CUCM.
Reason: here is an ouput from CUCM DB; copy paste the below on a notepad your will understand much better..
admin:run sql select * from enduser where userid = "test"
pkid                                 assocpc firstname middlename lastname userid manager department telephonenumber tkuserlocale mailid status facsimiletelephonenumber mobile pager homephone title building site fkdirectorypluginconfig uniqueidentifier nickname deletedtimestamp passwordreverse fkmatrix_presence                    tkuserprofile fkcallingsearchspace_restrict allowcticontrolflag enablemobilevoice maxdeskpickupwaittime enablemobility remotedestinationlimit ocsprimaryuseraddress enableemcc fkucserviceprofile directoryuri islocaluser fkfeaturegrouptemplate
5f7d238c-17cf-345f-fdab-f6b96532242e                              test     test                                      NULL                1        NULL                                              NULL                             ad243d17-98b4-4118-8feb-5ff2e1b781ac 1             NULL                          t                   f                 10000                 f              4                                            f          NULL                            t           NULL
admin:
Here we do not find a column which has the field PIN.
So inconclution.. you cannot change something that does not exists..
Unless someone can correct me..
You not will find a field PIN in the enduser table because the password / pin is stored in the table "credential".
But when I try to update via SQL update command the "tkcredential" 4 which is the CREDENTIAL_PIN I get back the error message "No UPDATE permission for credential."
As you can see here what tkcredential means:
enum name     moniker
3    Password CREDENTIAL_PASSWORD
4    PIN      CREDENTIAL_PIN
So does anybody knows how to update the field "credentials" in the table "credential"?
BR
Michael
