4900
Highlighted
Beginner
Update TFTP Address on IP Communicator
Hi Voice team, i change the CUCM on my company to version 9.1.
I had to change the ip address, the problem is that now I have more than 100 ip communicator, how do I dynamically change the TFTP address that is registered?
Thiago
2 ACCEPTED SOLUTIONS
Highlighted
Hi.
The windows registry key mentioned by Chris is HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems Inc.\Communicator
TFTPServer1 (the ip address is written in decimal or hexadecimal)
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Highlighted
tftfp1: 56022f0a
tftp2: 57022f0a
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
23 REPLIES 23
Highlighted
Hall of Fame Master
It is stored in the registry, so if you can push the registry update it would be the easiest, assuming you are not using default and pulling it from DHCP scope.
HTH,
Chris
Highlighted
Hi.
Carlo
Highlighted
Just to add to excellent suggestions by Chris and Carlo (+5 guys), the hexadecimal values is read backwards..
eg..here is the hex value of my tftp server in the registry
e01fa8c0
e0=224
1f=31
a8=168
c0=192
so the ip will be
192.168.31.224
Highlighted
I found this parameter in hex, but how I put the IP of the new CUCM?
Highlighted
You need to convert your ip to hexadecimal...You can use this link to convert hex to dec or dec to hex
http://www.statman.info/conversions/hexadecimal.html
Highlighted
I made the conversion from my new ip 1047286 and the hex is ffaf6, i put on TFTP parameter, but the ip communicator
did not change the address.
Highlighted
That conversion is wrong..can you confirm that your ip address is 10.4.72.86? I will do the conversion for you
Highlighted
the ip address is 10.47.2.86 TFTP1 and 10.47.2.87 TFTP2
Highlighted
tftfp1: 56022f0a
tftp2: 57022f0a
Highlighted
Thanks, after put this,i need to reboot my windows?
Highlighted
Not really..I am running Windows 7 and I didnt need to restart my mahcine. Ensure you exit the IP communicator and start it again, if it doesnt still work, try and restart it
Highlighted
It works only on TFTP 2, on TFTP 1 still the old ip address on IP communicator
Highlighted
Ensure you have entered it correctly...If it works on one, it has to work on the other--or restart the pc
Highlighted
Thanks a lot voice team.
