Upgradation CUCM 11.X Failed Using PCD
Siva chinap
Level 5
Level 5
I got a issue while upgrading, how i can fix it.
7 Replies 7
Mohammed Khan
Try restarting "Platform Administrative Web Service" Service and check if that makes any difference/.
Siva chinap
Level 5
Level 5
Dear All,
Even after restarting PAWS service in PCD i am unable to upgrade, it's getting failed.. how to resolve this.
From which version you're trying to upgrade?
If its from 8.x for example you'll also need to start the following service: "Platform SOAP Services" on CUCM
Marc,
I am trying to upgrade from the Version 7.1(5) to 11.0.
I'm not sure if such a big step is possible. I'd upgrade to 8.6.2 and then to 11.X in your case
Once in 8.6.2 you need to install the following files:
  • ciscocm.version3-keys.cop.sgn
  • ciscocm.vmware-disk-size-reallocation-1.0.cop.sgn
And also start the following service:
  • Platform SOAP Services
Another idea is to make a fresh install of 11.x and try to migrate everything from 7 to 11 through PCD.
You want to read the PCD documentation, because that's IMPOSSIBLE to do with PCD.
PCD can UPGRADE only from 8.6 and above.
PCD, however, can MIGRATE from 6 and 7 releases
UPGRADE is NOT the same as MIGRATE, they're NOT equivalent terms
Which one are you really doing???
java
if this helps, please rate
tarunkodumuru
Level 4
Level 4
I am having Similar Issue when performing a Refresh Upgrade from UCCX 10.5 to 11.X. Did anyone test in lab and found a solution.?
Tarun
