03-22-2010 05:43 AM - edited 03-15-2019 09:53 PM
I need to change the firmware on a 7961g from sccp to a SIP image and I have downloaded the latest version 9.0.2 and it is a .cop.sgn file. Does anyone know how I get that onto the phone or what I do with it. All the guide I have found on the internet use .bin and .loads files so I'm a little unsure of what to do or if this is the right thing.
Many Thanks
Solved! Go to Solution.
03-22-2010 05:50 AM
I assume that you just have the phone and not Callmanager? if thats the case then this url should be useful
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
What you have downloaded is the SIP image for a Callmanager running Linux which is no good.What you need is the zip file
which is in the same place you got that file.
Cheers
Mark
Please rate useful posts
03-22-2010 05:50 AM
Cheers
Mark
03-22-2010 05:57 AM
That sounds about right, Ill download the right one,
Cheers
03-23-2010 08:47 AM
Would you be able to tell me which one I need to download as there were three there, is this the one I need: cmterm-7941_7961-sip.9-0-2SR1.zip
Thanks.
03-22-2010 07:16 AM
There is a nice guide to SIP conversion for the Cisco 7961G
12-12-2019 10:18 AM
Hi to ALL of you !!
I purchased a couple of 7961G phones off from eBay, and I want to convert them to SIP. I tried the quide mentioned in the post, but I don't have the CallManager, and the image I download and extract in the root of my tftp server does nothing. Currently the firmware it contains is: SCCP41.8-3-1S (if that helps)
Can somebody please help me? I would really appreciate it VERY much !!
12-16-2019 02:18 AM - edited 12-16-2019 02:19 AM
When you say "does nothing" do you just mean it doesn't upgrade, or is that absolutely no TFTP traffic indicating an attempt to upgrade. Check the release notes for your desired version, it may be that an intermediate upgrade is needed to go from 8.3.1 up to the current version.
If you're still having trouble then take a Wireshark trace and see what's going on, and also confirm exactly what files you have in the TFTP root directory
Have you deleted all settings from the phones?
