11-22-2017 07:48 AM - edited 03-17-2019 11:39 AM
Can someone please help me, and tell me how to upgrade from 3PCC to CUCM firmware, or if it is even possible? I tried to put in the correct load name and restart the TFTP with no luck.
Thank you,
John
Solved! Go to Solution.
11-28-2017 08:32 AM
Fixed the issue. Below are the instructions that I found, HOWEVER do not unzip the downloaded file.
https://supportforums.cisco.com/t5/ip-telephony/8800-upgrade-from-3pcc-to-enterprise/td-p/2960965
Thanks for everyones reply.
John
11-22-2017 11:40 AM
Chances are you are hanging on to that old server info.
I would start with this:
If you are still having trouble check the network settings on the device and verify it is grabbing an IP and has the correct tftp server ip's etc.
11-28-2017 06:09 AM
Thanks for the response, unfortunately the server info is not the issue. It will not accept the tftp transfer, just says update fail with an unknown error.
11-22-2017 01:09 PM
Someone posted the whole procedure they followed to do what you're asking in a thread at CSC, have you tried searching for previous related threads?
11-28-2017 06:13 AM
Thanks for responding; I was able to find the how to, but the phone keeps failing the upgrade. I have even tried a standalone tftp directly to the phone and it just fails, with an unknown error.
11-28-2017 08:32 AM
John
05-24-2018 07:27 AM
05-25-2018 06:30 AM
