Upgrade Call Manager from 8.6.2 to 10.5
Yannick Vranckx
Level 2
Level 2
Hello All,
We are planning to upgrade a Cisco Call Manager Publisher node from 8.6.2 to 10.5. We want to install a new publisher on a new environment, but we are struggling with some questions.
If we install the Pub node 10.5 can we migrate the configuration from the 8.6.2 to 10.5? Do we need a special tool for this?
If above doesn't work, we can still migrate the existing call manager towards the new servers and start the upgrade, the only problem we face there is that we have to change the publisher's IP because we want to use a new ip addressing scheme.
Kr,
Yannick Vranckx
5 Replies 5
Ayodeji Okanlawon
Your best bet is to use the new tool: cisco prime collaboration deployment. This fits perfectly into what you want to do here and can easily help you with all aspect of the migration including the ip address change. You can learn how to use the tool here..
https://www.youtube.com/watch?v=JzG4kz1_hL4
Please rate all useful posts
Ayodeij Okanlawon,
Great suggestion thanks, i've been testing the tool in the lab and it seems like very good tool for doing this.
Will be testing out the migration tool very soon live
The only thing I would add is that the tool is not error-free and some things may not work as you expect. In our case, creating the publisher was a simple task however we faced some difficulties with a subscriber. We had to do it completely separate. Make sure you ask for the proper OVA if you are deploying in a virtual environment.
The video says private.  Can you provide a login?
Mick,
Not sure what that was. Try this link or search on youtube for (cisco prime collaboration deployment)
https://www.youtube.com/watch?v=nMrS0hMES7A
