Upgrade Callmanager 4.0
columoconnor
I have a Callmanger 4.0(2a) and want to upgrade to CUCM 8.....Is there a path for this?
thanks
Colum
Jaime Valencia
Kinda, in many hops.
You need to go to 4.1(3) or 4.2(3) as the 1st hop.
Then to a 6.X or 7.X, and then finally to 8.X
Supported Cisco Unified Communications Manager Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
If you ask for a direct upgrade the answer is no.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
6 Replies 6
Jaime Valencia
java
java
thanks for the response
Seems like it would be easier to install new with 8.0 and reconfigure ...Is there a way to do this without purchasing new licenses
thanks
Colum
Reach our licensing team at licensing@cisco.com and they can help you migrate the licenses, they'll let you know what info they need.
You need to know the MAC address from the licensing server (PUB usually) so until you know it, don't reach them as the license is binded to it.
java
java
Rob Huffman
Hey Java,
Hope all is well
+5 for this great help here! I've always been curious (so I thought I'd finally
ask an expert) why there are many references in the doc you linked and in
other docs on CCO to the fact that DMA migration to many 5.x and 6.x CUCM versions
shows support from CCM 4.0(2a)??
Here are two such examples;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp92373
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp57424
Cheers!
Rob
I'm not sure why 4.0(2) shows there, none of the Linux versions use that one as the foundation (later on I explain the importance of this).
5.X uses 4.1(3) as blueprint and 6.X uses 4.2(3).
Even if you look at the documentation for DMA, 4.0 is not mentioned, even when the upgrade matrix shows that it's possible.
Data Migration Assistant User Guide Release  6.0(1)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/dma/6_0_1/dmaug601.html
DMA assists you with the first step in migrating  Cisco Unified Communications Manager data from versions 4.1(x) and  4.2(x) to Cisco Unified Communications Manager 6.0(1) by backing up this  data in a format that Cisco Unified Communications Manager 6.0(1) can  read.
You always need to be in the latest release of whatever train you're on. In the early days DMA lacked validation for this and you could get a DMA file from a 4.1(2) or a 4.2(1) CCM. Later this was enforced so you couldn't run DMA on any of those versions.
Usually the closest the versions are related to features is the upgrade path you can use.
ie 6.1(5)/7.1(5) are closer to 8.5(1) featurewise than previous 6.X or 7.X releases, so it's easier to upgrade.
But notice that they are the latest releases for their trains.
java
java
Thanks Java!
+5 for taking the time to answer such a question.
Your explanation makes perfect sense and I've always followed these
same rules
Cheers!
Huff
