upgrade cisco elm standalone server 9.1.1 to plm 10.0 faiure
shohamshalom
hi
i try to upgrade cisco elm standalone server 9.1.1 to plm 10.0 and after 4 minutes the upgrade fail.
i install before the cop file "elm_Elm_v9_1_1_PlmUpgrade.cop.sgn"  and after insure that it fine
i install the file "UCSInstall_UCOS_10.0.1.12900-2.sgn.iso"
my cucm is upgrade fine and allso unity connection
i attach the fail log from elm server
help!!!!
tk
shoham
7 Replies 7
Evgeniy.Suvorov
Did you install refresh_keys cop file ?
No,becuase the keys file needs for version 10.5 upgrade as I understand in the release notes...
Please correct me if I wrong here...
please open the link - http://www.cisco.com/web/software/284832458/102770/Elm_v9_1_1_PlmUpgrade_README.txt
there isn't  key file needs in version 10.0 according cisco pdf....
Tk
Shoham
Hi Shoham,
I was just referring the release notes of link which says that
You can upgrade a standalone Enterprise License Manager Release 9.1(2) deployment to a standalone Cisco Prime License Manager Release 10.x deployment.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/10_0_1/releasenotes/CUCM_BK_P73D8919_00_plm_rn_1001.pdf
Even I am not confident on the same but thought of sharing.
I was just browsing for any  bugs associated.I suggest opening TAC case.
Create a COP file for ELM standalone to PLM
CSCui86461
Symptom:
Unable to upgrade from ELM standalone 9.1.1 to PLM 10.x
Conditions:
Performing an upgrade
Workaround:
Modify the 9.1.1 /etc/opt/cisco/install/conf/*_product.xml file and add the following in the element section for the elm deployment:
description='Prime LM upgrade'>
CiscoPrimeLM.*_%{VERSION}.iso
description='Signed Prime LM upgrade'>
CiscoPrimeLM.*_%{VERSION}.sgn.iso
regds,
aman
hi aman
i did upgared to 9.1.2 but cant update to 10 yet
i m not sure whitch xml file do you mean to modify?
now my elm server is runing on 9.1.2 version ....
thanks
shoham
Did you install elm_Elm_v9_1_1_PlmUpgrade.cop.sgn ?
yes
i wrote it in the top .....:)
Hi Shoham,
what is the error message u are getting now?
regds,
aman
