03-16-2022 12:24 PM
I need to upgrade the IOS device G204XM , today I'm on version 15.4(3)M3, and I would like to go to version 15.8.3M7, so I would like to know if I can go straight or if there is a version before going to the new version ?
03-17-2022 12:55 AM
- Check Release Notes for targeted version , look for upgrade and installation notes and or dependencies ,if any.
M.
03-17-2022 10:34 AM
I already looked, but I didn't find it
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/15-8m/release/notes/15-8-3-m-rel-notes.html
03-17-2022 11:44 AM
There are likely no issue to go directly between these two releases.
09-23-2022 07:25 AM
Hello all
I am also upgrading our VG204XM from Version 15.7.3M to 15.9.3M6. Current rommon running on this device is Version 12.4(20r)YA2. On Cisco software download site I can't find any rommon image available for this device.
Does anyone know if I need to upgrade the rommon for this IOS upgrade, and if so where can I find the rommon image?
Thanks!
09-23-2022 07:48 AM
Pretty sure that you can upgrade to that release without issues.
