Walkthrough Wednesdays
1801
mmoreno_mnet
Beginner
Upgrade CME 7.1 to CUCME 9.1
Hello. I have a CME 7.1 running on a 2811, I need the newest version of the CUCME, For doing this I know I have to change the platform to a 2911, but what I wanted to know if the license I have on the CME7.1 can be transfer to the 2911 or I need to purchase all the license on the new platform???
4 REPLIES 4
paolo bevilacqua
Hall of Fame Master
CME license cannot be really transferred as in fact are paper licenses only.. However the 2911 must purchased with UC license.
akram.alrawi
Beginner
We Have 2901 which came with IOS 15.0/CME 7.1. When I installed a new IOS 15.2/CME 9.1 and enabled telephony-service it says the telephony-service is a trial version for 60 days and we need to purchase a license. Is there a way to upgrade the CME ?
In upgrading the IOS you are in fact upgrading the underlying CME release. Unfortunately in your case this does not mean upgrading CME resolves your licensing issue. As Paola mentioned in the previous post you need to purchase a UC license and install it to provide the CME features you require. If the router was purchased as a voice bundle it should have the uck9 feature license installed. Once installed upgrading to another later IOS your licenses are still preserved. You can verify what features re installed by using the show license feature, or show license all.
Allan
Thanks Allan,
Itried the show license command as well as the show version comman. The output of the two commands are conflicting.
show license feature:
Feature name     Enforcement      Evaluation     Subscription     Enabled     Right
uck9                    yes                    yes               no                    yes          yes
ios-ips-update          yes                    yes               yes               no               yes
Show version:
Technology          Current               Type               Next reboot
uc                         uck9                    permanent          uck9
Content for Community-Ad
Spotlight Awards 2021
