UPGRADE CUC 8.0.3(2a) to version 9 in a ucs server
I have installed the correct lic files in the cuc which is run in the ucs
I have installed the cop.sgn file(refresh upgrade) , and then i tried to upgrade to 9 but without success
The iso file that i used is UCSInstall_UCOS_9.0.1.10000-37.iso
The reason that the upgarde is not moving forward is that the cuc does not recognize the above iso as a valid upgrade
I am doing anything wrong?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
3 Accepted Solutions
Harmit Singh
Hi Chrysostomos,
That's probably because the filename is not correct. It should be "UCSInstall_UCOS_9.0.1.10000-37.sgn.iso". Rename it and try again.
HTH.
Harmit.
Glad I could help :-)
As for the licensing query, here is a link for FAQs on ELM:
https://supportforums.cisco.com/docs/DOC-27483#Q_Is_a_permanent_Internet_connection_needed_for_licensing_or_can_I_do_this_via_temporary_connection_and_cut_the_connection_once_ELM_has_connected_with_Cisco
  • Pre-9.0 Licenses can be migrated using ELM.
  • Upon registration, products who have been upgrade from pre-9.0 will report DLUs to ELM for migration to 9.0 licenses.
  • Based on reported license 9.0 usage and available DLUs, the customer can use a migration tool to decide how to best utilize DLUs to best satisfy current license demands.
  • Generate a License Migration Request
  • Go to the License Migration Portal and paste in the License Migration Request in order to receive your license file via e-mail.
  • Install the licenses at ELM.
HTH. Please rate if helpful.
Harmit.
Hi Chrysostomos,
As per that FAQ link:
Q: Can customers download ELM separately? If yes, from where?
A: It comes as a part of CUCM 9.x Media. During installation you can choose if you want it to be CUCM and ELM, or only ELM.
Q: I am still not clear on the ELM part. Is it going to be a separate server that runs apart from publisher and subscriber?
A: You can have it as a separate stand along server, or you can co-host with one of your CUCM servers.
During the installation, If you choose the option to install "Call Manager", ELM gets installed as a Co-Resident ELM.
If you choose the option of ELM install, then Standalone ELM will be installed.
Yes, it is mandotory to have an ELM server (standalone or co-resident) starting version 9.0 as the licensing architecture has changed. Follow the steps I provided to be able to migrate your DLUs to ELM. Here is the link for the License Migration Portel:
https://tools.cisco.com/SWIFT/LicensingUI/migrateDisplayProducts
Harmit.
5 Replies 5
Harmit Singh
Hi Chrysostomos,
HTH.
Harmit.
Oups ,
gread
Thank you harmit
I have downloaded from cisco , and i didnt noticed that the name it was not correct
Thank you again
One another question about the license for version 9
The server must have an access to the internet for the migration
Or is a locally Procedure
Harmit.
Harmit thank you for the replyies
Are very usufull
But i get very confused
For version 9 i have to install ELM in a separate server?
Does this neccesary?
How can Generate a License Migration Request
WHERE IS This portal?
Thnak you in advance
Hi Chrysostomos,
Harmit.
