06-17-2020 09:47 PM
Hi guys,
Please, would anyone know how to upgrade CUCM 11.0 to 11.5 is considered a version change, where it will be necessary to migrate the licenses through an active licensing agreement?
Or, is it just a simple CUCM release update, with no license migration required? After the upgrade you do not need to take any action with Cisco regarding licensing
Solved! Go to Solution.
06-17-2020 10:17 PM
There is no impact on licensing for this upgrade as it’s a minor upgrade. No actions are needed.
06-17-2020 10:17 PM
06-18-2020 03:30 AM
There's no licensing change but to be entitled to the 11.0 -> 11.5 upgrade the installation should be covered by an active support contract.
