Upgrade cucm 6.1.2 to 7.1(5)
Hi All,
Can I upgrade to cucm 7.1.5 from 6.1.2. Hws the upgrade path, it would be great if someone can guide me
Asif
6 Replies 6
phooghen
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp288546
Cisco Unified Communications Manager
7.1(5)
System Version
7.1.5.10000-12
Release Date
Apr 19 2010
Standard Support
Direct upgrade:
7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1, 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade from 6.1.2 to 7.1.5 is not supported.
It should be a 2 steps process.
From 6.1.2 to 6.1.3, then from 6.1.3 to 7.1.5
Pierre.
Thank you for the reply. I will tryi in two when I get the licese file for the same.
Is it possible for me to use 6.1.2 attendant console software with 7.1(5) version.
Asif
Asif,
Did you figure this out?
I am trying to see if AC can be used with 7.1.5
thanks,
Mike
Yes Mike.
We can use the same software with 7.1.5, I used the the one with 6.1.2. Also if it is an upgrade you will even get AC in plugin with 7.1.5.
Asif
Thank you Asif,
this is very helpful!
Mike
nitsinha
Level 4
Level 4
Hi Asif,
Check the Call manager software compatibility matrix
Upgrade from 6.1.2 to 7.1.5 is not a direct upgrade. Check the doc for the more details.
Nitesh
PS: Pl rate helpful posts
