UPGRADE CUCM 7.1.3 to 8.6.2A Best Practice Help!
leiboldsp
We have a single publisher/subscriber running 7.1.3 as well as a single Publisher Unity Connection server running 7.0.2 and Cisco Emergency Responder 7.1.3.  There are several questions that I have pertaining to our production environment.  We have roughly 300 phones.  Can we do the upgrade to the CUCM servers while the CUCN and CER servers stay at said state versions?  What effects of the CUCN (7.0.2) and CER(7.1.3) running with CUCM servers running 8.6.2a?
2.  Do we have to upgrade all four servers at once?
3.  Can one PRI run two cluster environments running on two different versions?
Old is 7.1.3 and New 8.6.2a?
Vipul Jindal
check the release notes for CUCM 8.6.2 and make sure UC and CER are supported or not.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_6_1/cucm-rel_notes-861.html
if they are, you can only upgrade the CUCM vesion wihtout upgrading the UC and CER.
if you are running H323 than you have 2 cluster envirnoment but i dn know how you will route the same DID number.
thanks,
Vipul Jindal
Just to add for question 3 as Vipul said (+5) with H323 it's as simple as pointing different dial-peers to different CUCM servers, so you may need to break your DID ranges, or you can simply route all calls to one cluster and then transfer appropriate calls to another via Intercluster trunk, so this would not require H323 and would work with any protocol.
For question 1-2 see the compatibility guide for links to appriopriate UCON and CER compatibility information:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
HTH,
Chris
