09-27-2011 01:31 PM - edited 03-16-2019 07:13 AM
i have virtual CUCM 8.5 on UCS B series and need to upgrade it to 8.6 any one can help or send me material to tells me what is the recomendations
and restriction ?????
09-27-2011 01:51 PM
09-27-2011 04:32 PM
For CUCM 8.5 to 8.6 upgrades the most important thing to be aware of is this.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_6_1/cucm-rel_notes-861.html#wp1971086
09-27-2011 05:47 PM
Also remember that the upgrade involves a kernel upgrade and takes an extra 30 minutes to an hour. It's all covered in the release notes.
09-30-2011 07:03 AM
Joe, thanks for this information. I have lab where a Pub has been from 8.0.3 to 8.5.1 to 8.6.2 using the COP, no problem most of the time. However, when deplyoing a new Sub from scratch, I cannot install the COP during upgrade/patch routing in installation. Without that, the 8.6.2 upgrade patch fails during installation and trying to join 8.5.1 to the Pub will not work.
Is there a proper way to do that or should we always use a bootable DVD to re-install or deploy a new 8.6.2?
Thanks.
09-30-2011 07:47 AM
In that case you would need to use a bootable 8.6.2. As you found you cannot apply the cop file to allow an install with upgrade from 8.5.1 to 8.6.x.
09-30-2011 07:52 AM
Thanks a lot Joe.
10-23-2011 12:42 PM
I had the same problem with joining a new Sub to an 8.6 cluster. I just downloaded the 8.6 upgrade files from CCO and converted them to a bootable DVD. It's not supported by Cisco, but until we start seeing 8.6 bootable disks, there is not a lot of choice. Why they don't just make the downloads bootable puzzles me.
