ā02-07-2016 09:06 AM - edited ā03-17-2019 05:47 AM
Hi All,
Greetingsā¦..
We are planning to upgrade CUCM from 10.5.2.12901-1 to 11.0.1. But I need the complete compatibility matrix for CUCM 11.0.1 as we have multiple application servers running. So if I upgrade CUCM to 11.0.1, I am not sure whether remaining servers will support with existing versions. I am attaching the list with their versions.i didnāt find any document for matrix. But I found below link in which it tells us to click āhereā. Where that āhereā button doesnāt work for me.
Can someone help me out in this. Attaching our devices/servers with existing version.
Sankar.
ā02-07-2016 11:52 PM
Hi Sankar,
From that compatibility list, it seems like UCCX, Unity connection and presence also needed upgrade to 11.0 versions in order to be compatible.
Rajan
ā02-08-2016 01:21 AM
Hi Sankar,
Manish and Deepak have already shared links which are only available . I could find the below link.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/11_x/cucm_b_cucm-imp-compatibility-matrix-11x.html
I suggest opening TAC Case before proceeding with upgradation.
regds,
aman
Hi Bhavani,
Here are a few
Unity Connection
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/compatibility/matrix/cucclientmtx.html
Basically any version of Unity Connection 7.x and later will be compatible with all CUCM 10.x and 11.0 versions.
UCCX
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.6%281%29
For Presence, If you are deploying CUCM 11.0.1 , then similar 11.0.1 needs to be deployed for Presence.
IOS is generally backward compatible so it should not be an issue.
Manish
ā02-08-2016 12:05 AM
(+5) to Manish
The CUCM compatibility matrix is quite confusing :).
So Manish,
UC does not need an upgrade.
UCCX 10.6 is compatible with CUCM 11.0
Presence definitely needs an upgrade to 11.0
Correct ?
Do we also have any links for VCS compatibility with CUCM 11.x
Rajan
ā02-08-2016 12:20 AM
Hi Rajan,
That is correct. From the Unity Connection compatibility matrix
IM&P 10.x onwards , the version needs to match with cucm like 10.5.2 with 10.5.2 , 10.0.1 with 10.0.1 etc, this is mentioned in the install guides.
For VCS, if we check the following link then only 8.7 version is compatible with cucm 11.x
http://www.cisco.com/c/en/us/support/unified-communications/telepresence-video-communication-server-vcs/products-installation-and-configuration-guides-list.html
Manish
ā02-08-2016 01:37 AM
Thanks for the clarification Manish.
ā02-08-2016 12:32 AM
Please note UCCX Compatibility Matrix for 10.6.1.10000-39 does not show 11.0.1 but instead 11.0(1a) and that too you will need to apply the ciscouccx.106x.cucm11-compatible.14.cop.sgn cop file for it to get working.
I assume it should work with 11.0.1 as well after applying the above COP file but it will be worth to confirm with TAC what their take is on this.
Deepak
