Upgrade CUCM from 7.1.5 to 8.0
Yazen Alaa
Dear All
I have two  CUCM (publisher , Subscriber ) version 7.1.5 MCS server , my Questions are following as below :
1) if i want to upgrade to 8.0 , it will be directly from install/upgarde software then put CD/DVD version 8 then upgarde ????? or i have re-build the server from begining : take the backup from version 7.1.5 by DMA then  to re-install the publisher server then add Backup then go Subscriber and do the same steps at publisher ????
2) if i need to re-install or rebuild the server , which remonnaded way to start from publisher first or from subscriber (all phones registered first on subscriber then publisher)  ?????? can you give me the steps to upgrade ???
your answer is very importnant for me
thanks
Ηι
Direct upgarde means that from 7.1.5 will go to 8.x version with ONLY one upgrade
Non direct upgarde means multible upgardes before you go to desire version
The below shows you from the version that you are now to which version you can go directly(with only one upgrade)
  • •1)      Cisco Unified Communications Manager Software Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
Here is the hardwatre compatibility matrix
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
General:
First you have to upgarde the PUB.Then the upgrade version will go to the inactive partision
Then upgrade the SUB.
Once SUB finish and the upgarde version is also to the inactive partition then go and  switch version first to the PUB
Once PUB comes up , then go ahead and do the same with the SUB
After all check the replication status from the Pub to be sure that teh replication is ok between PUB and SUB
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Jaime Valencia
The FAQ which is on top of the main page, covers your questions.
ANNOUNCEMENT: IP Telephony FAQs and Basics - Please read before posting!
    If your server is compatible with the CUCM release, all you need to do is upgrade.
    Supported Servers for Releases of Cisco Unified Communications Manager (Including Business Edition 3000/5000/6000 and Session Manager Edition) and Cisco Intercompany Media Engine
    http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
    http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
    Assuming the version are a direct upgrade, you can do it in one hop, otherwise, you might need multiple hops.
    Review above information and also the FAQ.
    java
    if this helps, please rate
    www.cisco.com/go/pdihelpdesk
    java
    Hi Jaime
    I assume the hardware is supported , what you mean direct upgrade , just go to install/upgrade in OS page  then download version 8.0 , which one i will start publisher or subscriber first ???
    thanks for ur reply
    Any Reply ???
    thanks
    Ηι
    General:
    chrysostomos
