161
Highlighted
Beginner
upgrade cucm version 4.2 to 9.1 with new hardware
Dear All
I have three CUCM one publisher and two subscribers version 4.2 , and i have new hardware  Cisco UCS C240 M3 Qty:2 with Cisco Business Edition 7000  with version 9.1
what is the upgrade steps it will be to upgrade from 4.2 to 9.1 based on new harware ?
shall i take backup confiuration on cucm  version 4 by dma ? from where can i get the dma
thanks amd regards
3 REPLIES 3
Hi,DMA download link and
DMA download link and usage instructions are available at the following link. You will first need to build CUCM 7.X on MCS and upgrade it to 8.x / 9.x on MCS depending on whether your MCS server supports it. Then take a backup and build same version on UCS and restore the backup. Detailed procedure is available on callmanager install and upgrade guides which you can get by using google search.
Manish
Enthusiast
Hi,Pleas refere below link
Pleas refere below link for pictorial idea.
http://www.cisco.com/web/learning/le21/le39/docs/tdw_207_preso.pdf
Regards, Nishant Savalia
Advisor
Hi , you can download the DMA
Hi ,
you can download the DMA tool
http://software.cisco.com/download/release.html?mdfid=282421166&flowid=45895&softwareid=282074290&release=7.1(5)&relind=AVAILABLE&rellifecycle=&reltype=latest
but  with DMA , you can go upto call manager 7 only.
 you can also refer the upgrade path to desired call manager version by referring software compatibility matrix.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
But what I suppose BE7K comes pre-loaded with CUCM 9.1(2). Also, whether BE7K supports CUCM 7.1(5) is not clear.
you can speak to cisco SE for more details.
regds,
aman
Content for Community-Ad
August's Community Spotlight Awards
