03-30-2015 05:43 AM - edited 03-17-2019 02:29 AM
Does anyone know what would happened if you upgrade CUCM with extension mobility enabled?
Solved! Go to Solution.
03-30-2015 05:52 AM
Here is the documentation defect for the same:
https://tools.cisco.com/bugsearch/bug/CSCus10292/?reffering_site=dumpcr
Symptom:
This is a Documentation Defect :
In pre-10.x versions of CUCM, the upgrade guide specifies that EM services need to be disabled prior to upgrade. This was specified for DB reasons. The DB team has informed us that this requirement is no longer necessary after 10.x.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/10_0_1/CUCM_BK_U4214F9D_00_upgrade-guide-cucm-100.pdf
On page 44, under step 8, item c):
"Disable the Cisco Extension Mobility service by navigating to Cisco Unified Serviceability > Tools > Service Activation. For more information, see the Cisco Unified Serviceability Administration Guide.
Note that when you deactivate the Cisco Extension Mobility service, Cisco Extension Mobility users cannot log in and log out of phones that supp
Conditions:
no need to disable EM service during upgrades after 10.x
03-30-2015 05:50 AM
We need to disable EM during the upgrade otherwise it will write the change to the DB causing upgrade failure. However, as per a recent update you do not need to disable it if you are upgrading to version 10.x or higher.
Manish
03-30-2015 05:52 AM
Symptom:
Conditions:
03-30-2015 05:56 AM
So to be clear, if I'm going from 10.5.1 to 10.5.2, and I don't disabled it, I should be good?
03-30-2015 05:57 AM
Yes.
03-30-2015 05:58 AM
Thank you, this information was quite insightful and very helpful.
03-30-2015 07:50 AM
[+5] for sharing the info.
regds,
aman
08-24-2015 11:20 PM
Hi Manish,
We have migrated from CM 8.0 on MCS to CUCM 10.5(2) using PCD and EM services weren't disabled before migration and then CUCM 10.5(2) will be upgraded to SU2a using PCD as well.
However, we have noticed that, there is additional delay of few seconds post migration if EM services aren't disabled.
Does restarting EM services across cluster fix the delay?
As you have confirmed, 10.x to 10.x upgrade disabling of EM services isnt necessary.
But, not disabling it on source cluster on MCS causing this issue?
I don't see issues with db replication on cluster.
Please suggest.
Sami
10-01-2017 12:31 PM
Sami- How did you fixed the issue?
We have not disabled the Extensio Mobility while doing the Migrate from 9.x to 11.5 via PCD.
I am getting issues when users trying to login, the page for Entension mobility shows error 404 on phone.
Also i can make them login via remote URL, but from actual phone its failing,
