Upgrade File from CUCM 6.1 to CUCM 8.5
matthewlogan46
I am doing an upgrade. I'd like you to confirm me if the following files for installation are correct:
Active partition: 6.1.2.1000-13
File to Install: UCSInstall_UCOS_6.1.5.10000-10.sgn
Inactive Partition: 6.1.2.1000-13
Active Partition: 6.1.5.10000-10
File to install: UCSInstall_UCOS_8.5.1.10000-26.sgn
Inactive Partition: 6.1.5.10000-10
Active Partition: 8.5.1.1000-26
Are those all file to complete the upgrade from 6.1.2 to 8.5.1?
The file: ciscocm.allow_upgrades_to_unrestricted.cop.sgn, is necesary?
Thanks!
5 Replies 5
Chris Deren
Is there a reason you want to go to base 8.5.1 vs. 8.5.1SU4 for example? It would take the same amount of effort.
Check out compatibility matrix for supported upgrade paths:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Why would you want to go to unrestricted version? What country are you in?  Most typically installations are Restricted unless you cannot use it because you are in a contry that Cisco does not allow it.
HTH,
Chris
Thanks Chris.
About the version there is no particular reason. My country is Chile.
Chris Deren
You should not need unrestricted version in Chile, so no need to run the cop file.
Chris
Thanks Chris.
Matthew,
Did you require further assistance hence the low rating?
Chris
