03-29-2013 05:42 AM - edited 03-16-2019 04:31 PM
Dear All,
I am running Call Manager version 8.5
Is it possible that i can upgrade Call Manager 8.5 to 9.0 directly.
Kindly gudie me if i am wrong.
Malik.
Solved! Go to Solution.
03-29-2013 05:47 AM
Hi Malik.
Based on the following document the answer is yes.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Carlo
03-29-2013 05:52 AM
Just to add that you have to install ciscocm.refresh_upgrade_v1.1.cop.sgn file before proceeding with the upgrade.
You also have to convert your unused 8.5 License to 9.x and install them in 8.5 before upgrade,
Carlo
03-29-2013 05:47 AM
Hi Malik.
Carlo
03-29-2013 05:49 AM
you can upgrade from CCM 8.5 to CCM 9. you need just to make sure that your server support the new CCM version.
kindly find the below link
Anas
please rate if it is helpful
03-29-2013 05:52 AM
Carlo
03-29-2013 06:18 AM
Thanks to Carlo and Anas.
Thanks for your support
08-01-2013 10:57 AM
Hi Tiger
Did you upgrade CallManager 8.5 to version 9, Please share your experience
I am planning to upgrade CallManager 8.5 to 9 and would like to knwo the sequence of upgrade as well as License procedures.
Did you upgrade unity connection as well to version 9 or is it backward campatible with CUCM version 9
Thnaks in advance
08-06-2013 10:37 AM
successfully completed
