Upgrade from Call Manager version 8.5 to 9.0
tiger_401
Dear All,
I am running Call Manager version 8.5
Is it possible that  i can upgrade Call Manager 8.5 to 9.0 directly.
Kindly gudie me if i am wrong.
Malik.
2 Accepted Solutions
Hi Malik.
Based on the following document the answer is yes.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Carlo
Please rate all helpful posts "The more you help the more you learn"
Just to add that you have to install ciscocm.refresh_upgrade_v1.1.cop.sgn file before proceeding with the upgrade.
You also have to convert your unused 8.5 License to 9.x and install them in 8.5 before upgrade,
Carlo
6 Replies 6
Hi Malik.
Carlo
Anas Abueideh
Level 9
Level 9
you can upgrade from CCM 8.5 to CCM 9. you need just to make sure that your server support the new CCM version.
kindly find the below link
Anas
please rate if it is helpful
Carlo
Thanks to Carlo and Anas.
Thanks for your support
Hi Tiger
Did you upgrade CallManager 8.5 to version 9, Please share your experience
I am planning to upgrade CallManager 8.5 to 9 and would like to knwo the sequence of upgrade as well as License procedures.
Did you upgrade unity connection as well to version 9 or is it backward campatible with CUCM version 9
Thnaks in advance
successfully completed
