09-04-2012 10:09 PM - edited 03-16-2019 01:02 PM
Hello
We have a customer needs to upgrade the existed CUCM v5 to CUCM 8.6. Our issue that we find that we need multi hop upgrade from 5 to 7.1 and from 7.1 to 8.6, the problem that the upgrade from 5 to 7.1 became EoS.
What should we do?
09-04-2012 10:15 PM
Ahmed,
I am affraid there is no good news for you but you still might want to check with Cisco's Partner Helpline team to see if the upgrade can still be ordered as a special case. Please open a presales case with them from www.cisco.com/go/ph .
GP.
Pls rate the post if it helps !!
09-04-2012 10:26 PM
If there is no special case fot us. What is the procedure should we use?
09-04-2012 10:32 PM
Ahmed,
I've not come across such situation but I think it will need a fresh build ( includs fresh config of dial plan, integration etc ).
GP.
09-04-2012 10:42 PM
And what about the license?
09-04-2012 10:53 PM
License reissuing should be fine. Checkout either with Cisco's Partner Helpline team for licensing related changes across CUCM versions or mail to licensing@cisco.com
GP.
