04-02-2012 02:54 PM - edited 03-16-2019 10:26 AM
I want to upgrade for virtualisation reasons and I was hoping to get more insight into upgrade,
13 Upgrade TSP on both unity servers
Is this the right way? I have got different procedure and want to make sure I follow best one.
Can anyone please help
04-02-2012 03:16 PM
What is step 2 for? Makes no sense to me.
Steps 9 and 10 need to be performed after step 1.
Steps 7 and 8 have to be reversed as your servers will have the same hostname and IP address and if both are running at the same time you will create conflict
Don't forget licensing for going to version 8 on MCS and then new licenses for UCS.
HTH,
Chris
04-03-2012 02:48 PM
Step 2 is since MCS CUCM servers would continue working till I upgrade because my MCS servers do not support 8.0
I also saw few folks took a backup of 7.1 cucm and installed on UCS server (although not suported) and then did a direct 8.5 upgrade.
Would this be faster and easier to follow?
Thanks for your help!
04-03-2012 08:39 PM
Yes it would be faster and easier. But keep in mind it is not supported process and be ready with the new licenses for UCS server.
Ronak Patel
Please rate helpful posts.
