06-18-2013 05:09 AM - edited 03-16-2019 05:56 PM
Hello Guys,
I have problem to upgrade my 6921 phones from 9-1-1-0
When I try to upgrade them from the specified version to the last one (9-3-3-2) we have the following behavior:
- Phone reboot;
- Phone download the new firmware;
- Phone start;
- Phone "can't register";
- Loop on old firmware/new firmware.
I have the same behavior with phone running firmware 9-1-1-2-sr.
In the phone logs I have the following:
[13:58:14, 06/18/2013] upgrade SCCP69xx.9-3-3-2.zz.sgn from 10.31.1.10 |
[13:58:14, 06/18/2013] upgrade DSP69xx.12-4-122-02-121029.zz.sgn success |
[13:58:04, 06/18/2013] upgrade DSP69xx.12-4-122-02-121029.zz.sgn from 10.31.1.10 |
[13:58:01, 06/18/2013] SEP54781a6a8cb0 Get ip from DHCP server : 10.161.15.81 |
[13:57:31, 06/18/2013] system boot up (SCCP 9.1.1.0) |
[13:57:15, 06/18/2013] trigger reboot from UPGRADE_LOADS (system up time : 33434 ticks, 1 |
minute 6 seconds) |
[13:57:15, 06/18/2013] upgrade SCCP69xx.9-1-1-0.zz.sgn success |
[13:56:37, 06/18/2013] upgrade SCCP69xx.9-1-1-0.zz.sgn from 10.31.1.10 |
[13:56:37, 06/18/2013] upgrade DSP69xx.0-0-0-4.zz.sgn success |
[13:56:31, 06/18/2013] upgrade DSP69xx.0-0-0-4.zz.sgn from 10.31.1.10 |
[13:56:31, 06/18/2013] XMLDefault.cnf.xml.sgn (HTTP) |
[13:56:31, 06/18/2013] can't download configuration file SEP54781A6A8CB0.cnf.xml.sgn from |
10.31.1.10 |
[13:56:31, 06/18/2013] ITL installed |
[13:56:31, 06/18/2013] ITLSEP54781A6A8CB0.tlv updated successfully |
[13:56:31, 06/18/2013] ITLSEP54781A6A8CB0.tlv (HTTP) |
[13:56:31, 06/18/2013] ITLSEP54781A6A8CB0.tlv updating |
[13:56:31, 06/18/2013] CTLSEP54781A6A8CB0.tlv not found in 10.31.1.10 |
[13:56:31, 06/18/2013] CTLSEP54781A6A8CB0.tlv updating |
[13:56:30, 06/18/2013] XMLDefault.cnf.xml.sgn (HTTP) |
[13:56:30, 06/18/2013] can't download configuration file SEP54781A6A8CB0.cnf.xml.sgn from |
10.31.1.10 |
[13:56:30, 06/18/2013] ITL installed |
[13:56:30, 06/18/2013] ITLSEP54781A6A8CB0.tlv updated successfully |
[13:56:30, 06/18/2013] ITLSEP54781A6A8CB0.tlv (HTTP) |
[13:56:30, 06/18/2013] ITLSEP54781A6A8CB0.tlv updating |
[13:56:30, 06/18/2013] CTLSEP54781A6A8CB0.tlv not found in 10.31.1.10 |
[13:56:30, 06/18/2013] CTLSEP54781A6A8CB0.tlv updating |
[13:56:28, 06/18/2013] XMLDefault.cnf.xml.sgn (HTTP) |
[13:56:28, 06/18/2013] can't download configuration file SEP54781A6A8CB0.cnf.xml.sgn from |
10.31.1.10 |
[13:56:28, 06/18/2013] ITL installed |
[13:56:28, 06/18/2013] ITLSEP54781A6A8CB0.tlv updated successfully |
[13:56:28, 06/18/2013] ITLSEP54781A6A8CB0.tlv (HTTP) |
[13:56:28, 06/18/2013] ITLSEP54781A6A8CB0.tlv updating |
[13:56:28, 06/18/2013] CTLSEP54781A6A8CB0.tlv not found in 10.31.1.10 |
[13:56:28, 06/18/2013] CTLSEP54781A6A8CB0.tlv updating |
[13:56:26, 06/18/2013] SEP54781a6a8cb0 Get ip from DHCP server : 10.161.15.81 |
[13:56:12, 06/18/2013] DSPALLOC: AER instance 0, max_tail = 200 ms, usage = ( HS HeS HF |
GL_HS GL_HeS ) |
[13:56:12, 06/18/2013] DSPALLOC: AER instance 1, max_tail = 60 ms, usage = ( HS HeS GL_H |
S GL_HeS ) |
[13:56:12, 06/18/2013] ROOT: Hardware ringer :FALSE |
[13:56:12, 06/18/2013] Network: nw_create() ipstack_mode=2 |
[13:56:10, 06/18/2013] system boot up (SCCP 9.3.3.2) |
[13:56:10, 06/18/2013] DLM: Cannot alloc mem for internal msg (2) |
[13:56:10, 06/18/2013] DLM: Cannot alloc mem for internal msg (1) |
[13:55:54, 06/18/2013] trigger reboot from UPGRADE_LOADS (system up time : 120038 ticks, 4 |
minutes ) |
[13:55:54, 06/18/2013] upgrade SCCP69xx.9-3-3-2.zz.sgn success |
[13:54:00, 06/18/2013] upgrade SCCP69xx.9-3-3-2.zz.sgn from 10.31.1.10 |
[13:54:00, 06/18/2013] upgrade DSP69xx.12-4-122-02-121029.zz.sgn success |
[13:53:50, 06/18/2013] upgrade DSP69xx.12-4-122-02-121029.zz.sgn from 10.31.1.10 |
[13:52:25, 06/18/2013] SEP54781a6a8cb0 Get ip from DHCP server : 10.161.15.81 |
[13:51:55, 06/18/2013] system boot up (SCCP 9.1.1.2.sr) |
Thanks for your help !
Herve Jacquemin
06-19-2013 12:55 AM
No one has an idea about this ?
06-21-2013 01:41 AM
I have exactly the same problem. FYI, My old firmware is 9.3.1.3.
06-21-2013 01:49 AM
I opened a TAC case, when I have a solution, I will update the topic !
06-21-2013 02:48 AM
thank you very much. hopefully there will be a solution
06-24-2013 05:43 AM
I had an answer from the tac:
In the TFTP service logs we found:
12:46:55.122 | CReqContext::tftp[0xaf0234a0~15~10.161.15.81~1030] SEP54781A6A8CB0.cnf.xml.sgn file not found. Checking [SEP54781A6A8CB0.cnf.xml] to sign
12:46:55.122 |CReqContext::FindAndServe SignFileFlag[1]
12:46:55.123 |CCtftpChangeNotifyServer::HasWaitingEvent(), Empty List or pkid
12:46:55.123 |CReqContext::FindAndServe(1)[0xaf0234a0~15~10.161.15.81~1030],Not signing[SEP54781A6A8CB0.cnf.xml], on fly
12:46:55.123 |-->HTTPEngine::sendNak[0xaf0234a0~15~10.161.15.81~1030][1]
12:46:55.123 | HTTPEngine::sendNak[0xaf0234a0~15~10.161.15.81~1030][1] FileName[SEP54781A6A8CB0.cnf.xml.sgn], Version[HTTP/1.1]
12:46:55.123 | HTTPEngine::sendNak[0xaf0234a0~15~10.161.15.81~1030][1] [64][HTTP/1.1 404 Not Found
>> Phone requests general configuration file “XMLDefault.cnf.xml.sgn” and gets it:
12:46:55.142 | HTTPEngine::sendResponse[0xaf023e80~16~10.161.15.81~1031] FileName[XMLDefault.cnf.xml.sgn], Version[HTTP/1.1], Size[9947]
12:46:55.142 | HTTPEngine::sendResponse[0xaf023e80~16~10.161.15.81~1031] [85][HTTP/1.1 200 OK
Content-length: 9947
Cache-Control: no-store
Content-type: */*
12:46:55.142 |-->HTTPEngine::sendMessage[0xaf023e80~16~10.161.15.81~1031]
12:46:55.142 | HTTPEngine::sendMessage[0xaf023e80~16~10.161.15.81~1031] Socket[17], Length[85]
12:46:55.142 | HTTPEngine::sendMessage[0xaf023e80~16~10.161.15.81~1031] Send Complete, Size[85], Sent[85]
12:46:55.142 |<--HTTPEngine::sendMessage[0xaf023e80~16~10.161.15.81~1031]
12:46:55.142 | HTTPEngine::sendMessage[0xaf023e80~16~10.161.15.81~1031] Socket[17], Length[9947]
12:46:55.142 | HTTPEngine::sendMessage[0xaf023e80~16~10.161.15.81~1031] Send Complete, Size[9947], Sent[9947]
>> Phone requests firmware “9-1-1-0” and gets it:
Content-type: */*
12:46:56.683 | HTTPEngine::sendResponse[0xaf026fe0~21~10.161.15.81~1036] FileName[SCCP69xx.9-1-1-0.loads], Version[HTTP/1.1], Size[481]
12:46:56.683 | HTTPEngine::sendResponse[0xaf026fe0~21~10.161.15.81~1036] [59][HTTP/1.1 200 OK
And this goes into a loop from there.
The "Not signing[SEP54781A6A8CB0.cnf.xml], on fly” would mean taht the CUCM doesn't provide the secure configuration file to the phone. And he advice me to install the latest device pack on the CUCM.
WIll keep you updated if my problem is solved after or not !
06-24-2013 06:19 AM
Thanks for the update. By device pack, do you mean this: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
Anyways, what is your CUCM version? Mine is 8.5.1
06-24-2013 06:25 AM
yes that's that !
For you it's
cmterm-devicepack8.5.1.16100-2.cop.sgn
README: http://www.cisco.com/web/software/282074299/102825/cmterm-devicepack-8_5_1_16100-2_Readme.pdf
At my side I'm running 8.6.2
06-24-2013 06:46 AM
Hello hjacquemin,
Thanks a lot for the information. Please update if you are able to solve the issue . I will also download and try at my side
06-24-2013 06:49 AM
Your welcome Aldred.
I juste have a bad news our customer won't patch the cluster. The holiday period is approching, and he will upgrade in 9.x at the end of July.
He wants take any risk !
But keep me updated on your problem !
06-24-2013 06:57 AM
Haha i see. It's good to upgrade to version 9. But what I know is the licensing model changes dramatically in version 9. I think you need to consult with TAC regarding that issue
Anyways I will try to install the device pack and update here.
06-24-2013 06:59 AM
Indeed the licensing is very different ! And presence too all is manage by CUCM now.
Apparently the issue is at the CUCM side and version should solved my problem if I understand well. So wait and see !
08-06-2013 07:06 AM
Hello hjacquemin,
Did TAC provide any bug ID for this issue?
I am running 8.6.2.22900-9 and I have this issue also.
Thank you
08-07-2013 08:16 AM
Finally I have installed the latest device pack for CUCM 8.6(2) and that fixed my issue with the 6945 of my customer. They finally upgraded succesfully to latest software load 9.3.3SR1.
Thank you.
