12-19-2013 03:15 PM - edited 03-16-2019 08:57 PM
I have downloaded this file from the Cisco webpage:
Cisco Unified Communications Manager Express - 10.0 (cme-153-3Mv1.rar ) |
<TD style="PADDING-BOTTOM: 1px; PADDING-LEFT: 15px; PADDING-TOP: 1px" vAlign=top width="80%" mcestyle="padding-bottom: 1px; padding-left: 15px; padding-top: 1px;">CME 10.0 file set
<DIV style="DISPLAY: block; MARGIN-LEFT: 15px" id=imgDetails-0 mcestyle="display: block; margin-left: 15px;">
<P style="PADDING-RIGHT: 38px; FLOAT: left" mcestyle="padding-right: 38px; float: left;">Release Date: 30 Jul 2013
<P style="PADDING-RIGHT: 38px; FLOAT: left" mcestyle="padding-right: 38px; float: left;">Release: 10.0 <A style="FONT-SIZE: 11px" href="http://software.cisco.com/portal/pub/download/portal/select.html?mdfid=277641082&flowid=&softwarename=Unified Communications Manager Express Complete Support File Set&release=10.0&os=null" mcehref="http://software.cisco.com/portal/pub/download/portal/select.html?mdfid=277641082&flowid=&softwarename=Unified Communications Manager Express Complete Support File Set&release=10.0&os=null" mcestyle="font-size: 11px;">See All Releases</A></P>
<P style="WIDTH: 100%; FLOAT: left" mcestyle="width: 100%; float: left;"> </P></DIV>
<P mcestyle="height: 4px;">
<P style="PADDING-RIGHT: 36px; FLOAT: left" mcestyle="padding-right: 36px; float: left;">Size: 376.4 MB (394722279 )
<P style="PADDING-RIGHT: 12px; FLOAT: left" mcestyle="padding-right: 12px; float: left;">MD5: b77e4576d2b58f10e3d22fb23ff5a1e3
<P style="FLOAT: left" mcestyle="float: left;">
When unzipped and looking at the contents if references Version 9.5. Is this the correct file?
Thank You.
12-19-2013 04:26 PM
CME is embedded in IOS, you need to upgrade IOS.
12-21-2013 02:27 PM
Yes but are these the correct support files when it mentions 9.5 and not 10.0 even though the file on the Cisco web page says it is the 10.0 files? The flles were posted July 30, 2013.
12-19-2013 09:27 PM
Also you can check here for the IOS you need to install for any particular version of CME:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Sam
Please rate all helpful posts.
