Upgrade or new installation, Callmanager 7.0.2.20000-5 to 8.6?
alig.norbert
Enthusiast
Enthusiast
Hi all,
I have a CCM 7.0.2.20000-5 that should be upgraded to 8.6.
As mentioned in http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf , a direct upgrade is not possible.
I suppose an upgrade to 7.1x and then to 8.6 is not possible either, because 7.1x is EoS.
How can this be done? A new installation from 8.6 and a restore from 7.0.2?
Thanks for a hint.
Greets,
Norbert
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
If remember correctly, CUCM doesn't supports cross-release restore (wow).
If so, your only choice is either somehow obtain 7.1 media , or BAT export, and re-import.
paolo bevilacqua
Hall of Fame Master
If I can get a 7.1 media, the licenses from the installed 7.0.2 should still be active on the 7.1, right?
Well, let's asking our cisco sales ;-)
Norbert
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Paolo is correct, CUCM restores have always been on the EXACT (all the way to ES, SRs, etc) same version from which the backup was taken.
If you're going to do this all in one step you do not need any 7.1 licenses, once you upgrade to 7.1 you can immediately upgrade to 8.6 and then install the new licenses.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
